guzzi1 Posted November 1, 2008 Posted November 1, 2008 the saga continues and the girl is as hard to start as ever.played with the enrichner and fine tuned the valves and tried everyones starting suggestions but to no avail.so this weekend i'll try what the tech from calif. speed sport in tracy ca suggested.i'll remove the tank and pull the fuel pump out and tighten the clamps.he said this was not uncommon from the later v11 fuel system like mine.if this cures my starting problem i'll report here.my bike runs great after she's running and the starter cranks plenty fast so this is the the next and hopefully the last.daveg
docc Posted November 2, 2008 Posted November 2, 2008 So, you're saying she cranks and cranks, but doesn't fire? Then (maybe) she fires and runs fine . . . sounds like the middle (sidestand) relay, or the headlight relay (which also routes power the run switch). Does the neutral light come on?
