Thanks, wasn't sure. I thought the SuperTwin was designed to use the 5 speed, I had not heard that they had changed the design to use the 6 speed box in the newer models.
No, the Supertwin is a different motobike than the Monza as it uses the Ghezzi-Brian frame, GB swingarm, Braking perimetrical brakes and the 5 speed gearbox of the ol' 1100 Sport plus, apparently, the cam from the EV...
The Monza is a KIT you put on a V11 and as such it retains all motor characteristics of the V11 and it has the following:
- Body and front fairing
- Front/rear frames
- Seat
- Lights
- Aluminium gasoline tank and pump
- Belly pan
- Digital dashboard (optional)
Various options available.
- Paioli fork ø 41
- Mupo fork ø 43 or 46
- Mupo monoshock-absorber
- Braking system with Brembo radial calipers
- Stearing plates with setting trail
- Forged aluminium or magnesium rims
- Aluminium swivel arm
- Aluminium push rod with uniball
The only thing they sell now, as kits do nothing with the frame, so you keep the v11 frame with its geometry. I suppose you can still buy all parts to build a supertwin, including frame, only to get it legal on the road is a problem now.
