Slavomir Musilek (R.I.P.) Posted December 30, 2008 Posted December 30, 2008 I think this was already discussed here, I am thinking of upgrading my 2001 V11 with external fuel pump to new tank (without that ugly rubber pad) with internal pump fitted in. Now, is it just plug and bit of play with addapting the connectors and etc or is there more problems hidden? can you help?
ponti_33609 Posted December 30, 2008 Posted December 30, 2008 Hi, I believe I have read hear (others will confirm or not) that the new style tanks are slightly longer and will not fit. Hopefully I am wrong but I do not think so. I also think folks have done some interesting things to that ugly rubber pad to make it less of an eye sore. You can also get a replacement pad if yours is a mess from the dealers that are on here. Here is the post that Al did but to a 03 to 02 tank. Says the shorter red-frame bikes might not work. http://www.v11lemans.com/forums/index.php?...t=0&start=0 Best of Luck, Bob
