rideblue1 Posted February 10, 2009 Posted February 10, 2009 Does anybody know the capacity of the handlebar mounted clutch reservoir? I think it's 15cl but would like to know for sure,thanks.
Guest ratchethack Posted February 10, 2009 Posted February 10, 2009 Measuring the outside, I get ~3 cm dia and 2.5 cm height. where π = pi, π x r^2 x (height of cylinder) = volume π x (~1.5 cm)^2 x 2.5 cm = ~17.7 cc Dropping out an estimate for the volume of the thickness of the reservoir, it would likely be ~15 cc, or 1.5 cl to the MAX line. One o' you math whizzes kindly check this, please.
gstallons Posted February 10, 2009 Posted February 10, 2009 Why do you need to know the volume? I fill it up to just below the top.
rideblue1 Posted February 10, 2009 Author Posted February 10, 2009 ratchethack said: Measuring the outside, I get ~3 cm dia and 2.5 cm height. where π = pi, π x r^2 x (height of cylinder) = volume π x (~1.5 cm)^2 x 2.5 cm = ~17.7 cc Dropping out an estimate for the volume of the thickness of the reservoir, it would likely be ~15 cc, or 1.5 cl to the MAX line. One o' you math whizzes kindly check this, please. Wow thanks ratchetjack,I'm impressed!
rideblue1 Posted February 10, 2009 Author Posted February 10, 2009 gstallons said: Why do you need to know the volume? I fill it up to just below the top. I need a replacement cap and I can get a brembo one from a ducati which is a 15cl size and should do the job.
rideblue1 Posted February 10, 2009 Author Posted February 10, 2009 ratchethack said: Measuring the outside, I get ~3 cm dia and 2.5 cm height. where π = pi, π x r^2 x (height of cylinder) = volume π x (~1.5 cm)^2 x 2.5 cm = ~17.7 cc Dropping out an estimate for the volume of the thickness of the reservoir, it would likely be ~15 cc, or 1.5 cl to the MAX line. One o' you math whizzes kindly check this, please. Apologies.......RATCHETHACK.....
Guest ratchethack Posted February 10, 2009 Posted February 10, 2009 rideblue1 said: Apologies.......RATCHETHACK..... Por nada, mi compadre. I need a little math exercise once in awhile on stuff like this. . . NOTE: I b'lieve you'll find the capacity is 1.5 cl, (15 cc) -- NOT 15 cl, per calculation above. There's an order o' magnitude difference. Good luck.
grossohc Posted February 12, 2009 Posted February 12, 2009 ratchethack said: Measuring the outside, I get ~3 cm dia and 2.5 cm height. where π = pi, π x r^2 x (height of cylinder) = volume π x (~1.5 cm)^2 x 2.5 cm = ~17.7 cc Dropping out an estimate for the volume of the thickness of the reservoir, it would likely be ~15 cc, or 1.5 cl to the MAX line. One o' you math whizzes kindly check this, please. I concur
Guest ratchethack Posted February 12, 2009 Posted February 12, 2009 grossohc said: I concur Gracias, mi amigo.
