Guest Warren Posted October 15, 2003 Posted October 15, 2003 Can someone measure the width of the V11 front rotors, outside to outside, or possibly have this number recorded? Thank you.
Paul Minnaert Posted October 15, 2003 Posted October 15, 2003 Or you mean: from the manual: Front disk thickness: 4,1 mm. Front disk thickness, wear limit: 3,9 mm
Guest Warren Posted October 15, 2003 Posted October 15, 2003 Wrong measurements........ Take a tape or vernier caliper and measure from the outside of one rotor edge, go through the wheel and read at the outside edge of the other rotor. Hard to describe..........
Guest John T Posted October 15, 2003 Posted October 15, 2003 This is off a '01 Rosso Mandello. 14.1 Centimeters or 5.55 inches. I have full floaters so +/- a few.
docc Posted October 16, 2003 Posted October 16, 2003 Awright, Warren! What're you up to? You're fitting a 50's style dustbin fairing? Or a telelever suspension?
Guest Warren Posted October 16, 2003 Posted October 16, 2003 What're you up to? I have a set of V11 forks that I am considering installing on a '76 Lemans.
