chris a Posted February 12, 2009 Posted February 12, 2009 Ok Guys, anyone out there know the timing and lift for the V11 cam ???? Chris
Guest ratchethack Posted February 13, 2009 Posted February 13, 2009 Dunno, Chris. But if you post a Q over on the GuzziTech Tech Forum here: http://forum.guzzitech.com/index.php?optio...at&catid=30 -- or shoot Ed Milich an email over there: ed<at>guzzitech.com You should have your answers PDQ.
Guest ratchethack Posted February 13, 2009 Posted February 13, 2009 Don't know if all V11's are the same, but the Guzzi Service Manual for a 2000 Sport specs the following: CAMSHAFT TIMING: Intake: Opens 22° before TDC. Closes 54° after BDC. Exhaust: Opens 52° before TDC. Closes 24° before TDC. (no lift listed anywhere I could find)
Skeeve Posted February 13, 2009 Posted February 13, 2009 Exhaust: Opens 52° before TDC. Closes 24° before TDC. Are you certain you copied that correctly? I suspect that it's more likely Open 52deg BBDC Closes 24deg ATDC for the exhaust. Talk about overlap! 24deg ATDC; no wonder the v11 doesn't start to perk until after 5k rpm! Forgot all the other go fast bits: these things need VVT to recover their bottom end... Ah, heck: who am I kidding? Lugging it is bad for your motor anyway...
Guest ratchethack Posted February 13, 2009 Posted February 13, 2009 YIKES! That's it, exactly as printed. But you're right, and shame on me for not catching it!! Makes no sense, wotsoever. It's yet another misprint in the manual. My apologies, courtesy Cod. 01 92 01 31 Tech Pubs, MOTO GUZZI S.p.A. Via Parodi, 57 23836 Mandello del Lario
raz Posted February 13, 2009 Posted February 13, 2009 Searching this forum you can even get a graph of it http://www.v11lemans.com/forums/index.php?...st&p=137372
chris a Posted February 13, 2009 Author Posted February 13, 2009 Searching this forum you can even get a graph of it http://www.v11lemans.com/forums/index.php?...st&p=137372 Thanks lads. I used guzzitech a lot untill their last meltdown .Now the loading speed there is so long that I rarely visit. I really need to know the lifts in order to proceed ... Chris
motoguzznix Posted February 13, 2009 Posted February 13, 2009 Hey thanks Raz, I didn't remember I ever posted a cam graph on this forum. From the measured lift of 10.5 mm you have to subtract the valve play. Most important for the timing figures is the valve gap used for the measurement. Guzzi quotes this at 1.5 mm with a duration of 256°. My measurements show 254/253° which is very close. Better than measuring these figures is adjusting by measuríng the max valve oift of intake and exhaust.
Skeeve Posted February 14, 2009 Posted February 14, 2009 I used guzzitech a lot untill their last meltdown .Now the loading speed there is so long that I rarely visit. I know what you mean. I used to spend almost as much time there as here until they FUBAR'd the user interface: they were much better when they had the same simple graphic front end as WildGuzzi still retains... more meat, less bling is always my preference!
