Billd Posted February 16, 2009 Share Posted February 16, 2009 I've read Pauls item on replaceing a 6 speed into the place of a 5 speed on a series 1 Daytona. My question is can the same be done useing a 2007 Grisso 6 speed. How do the ratios compare? Looking forward to your comments. Link to comment Share on other sites More sharing options...
Skeeve Posted February 17, 2009 Share Posted February 17, 2009 I've read Pauls item on replaceing a 6 speed into the place of a 5 speed on a series 1 Daytona. My question is can the same be done useing a 2007 Grisso 6 speed. How do the ratios compare? Looking forward to your comments. Things can be done, I'm sure, but the new Griso & Breva 3-shaft 6spd trannies are different from the 4-shaft 6spd on a V11. I don't know how everything turns out, whether the 3-shaft is longer or shorter than the 4, whether or not output is the same distance from mounting points, etc. I think you'll be in the land of "suck it and see" to put that on your Daytona, but I believe part of the reason the 4-shaft layout was abandoned was to make a 6spd tranny that wouldn't require as many changes to existing models to update them, so you may even be better off than with a V11 6spd, I don't know... Good luck! Link to comment Share on other sites More sharing options...
