Tomaselli Clip Ons
Guest jlburgess
I'm considering putting a set of Tomaselli Clip Ons on a V11 Sport ('01). I'm wondering if they will be any taller than the standard risers. They look like the same rise from the picture I have. Does anyone have any feedback on them?
No, they are rather lower than the stock ones. There is a picture of my bike with these clip ons on the gallery (V11 naked
section).
Cheers.
Pierre
If you want to get a higher set of clip-ons, check out Two Brothers Racing! :thumbsup: I have a set of their clip-ons and they have different heights that can be used with their bars and fork clamps. Compleatly adjustable for every wrist! :bier: You will need the 54mm. fork clamps and then the 3.5 inch bar riser.
Care must be taken when changing bar height, turn the bars to lock with the engine running to see if the idle speed stays the same. If it doesn't you will need to reroute the cable, adjust the freeplay or replace the cable with a longer one.
Mike
Pierrot's bike with Tomaselli clip-ons:
Sorry Jaap, had to hack your Javascript :luigi:
If you want to get a higher set of clip-ons, check out Two Brothers Racing! :thumbsup: I have a set of their clip-ons... [snip]
Mike
...are these on the Rosso Mike? I'd like to see those installed in-person :luigi:
al
