Right Guys, planning a trip in May June across Europe to Turkey and back through Greece (to say hi to Dimitri) & Italy. I reckon its around a 5500 mile (9000K's) trip. Question is (and ignoring the fact you all love V11's) What spares to take? anything special to prepare before I go? will my ass die on the trip? What tyres will last the distance? My V11 is a 2003 registered but built in 01 with around 15K (miles) on it
At the moment its a toss up between taking my Triumph which I know is comfortable does 50mpg all day long and can do the mileage no problems but doesn't have much soul or the V11 which is relatively new to me (although have had / have plenty other Guzzis)
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
If its a Sachs rear shock then check for corrosion and cracking of the lower "eye"(as you wouldn't want it to fail mid trip )the seals can fail but there isn't really any way to check this so if you have any doubts fit a Hagon monoshock (approx £250)and forget about it.
You could fit some heavier bar end weights to reduce the vibes but the only part I can think to carry is a spare "cam sensor" as this would not be possible to work around if it failed.
There is no reason I can think of that would make a well maintained V11 a bad choice for this trip !
I'm sure others will add their thoughts.
Have a good trip
Dave
My longest was from Parma, Italy to Porto, Portugal via Corsica.
About 10,000 km in 5 weeks.
No spares, I just throw caution to the wind ^_^
I buy tires as I go.
Hiya Gino, all I would add to the toolkit would be a spare phase sensor, gear selector spring and relays. They take-up no space but could save the day in the middle of nowhere.
If I was going on a long trip I'd feel better if I brought:
- Spark plug and cap in case of a tipover.
- a couple extra relays
- shifter pawl spring and instructions on how to replace it if it breaks.
I don't know if your bike is in the range of bikes that may have a defective spring and/or oversized pawl boss that can lead to eventual breakage. Mine went at about 15k miles. I know that forum members Belfastguzzi and Slug both replaced their pawl springs on the side of the road, but having done mine at home it's not a job I'd want to do for the first time on the roadside. If I was in that situation far from home I'd have the bike towed to a repair shop, give them the instructions and the part, and let them do the repair.
The pawl spring failure poll might give you some idea of how vulnerable you are.
http://www.v11lemans.com/forums/index.php?...;hl=pawl+spring
Plug cap etc as above, plus
brake and clutch levers
small amounts of silicone sealer, Araldite / epoxy, tape, cableties, tieing wire, nuts/bolts/screws for leaks / cracks / breaks & other damage
latex gloves
rag
:stupid:
I also pack spare levers (get pattern ones for less than £20), starter solenoid and araldite. If its a long trip, I take a few nuts, bolts, washers and cable ties too- never seem to use 'em myself but I'm always giving them to others who need 'em!
I've done a couple of 3000 mile trips around Europe on the V11- had a few breakdowns / problems but always fixable.
Have fun
Guy
Crikey! I'm either brave or stupid. Serviced,new tyres and buggered off for 4000 miles... :D Shift spring broke before next trip, replaced it ,popped a new one in the toolkit and off again...
Thanks guy's, the one thing I will say is there does appear to be some common problems even with low mileage bikes (
I often do these trips on a Norton Commando so used to carrying spares and having unsheduled mtce stops. I do like the idea of the challenge on the Guzzi though. I'll keep you posted and I suppose I'll have to call Roberto Tenni so he can order me "essential spares" for the toolkit!!
My longest trip was 4500.From the UK to Brno for the GP,Hungary,Romania,Bulgaria,Greece,Italy,Switz,France,then home.I did this on my V11 Sport.Did not take any spares.And the V11 never missed a beat.Although I did get a new set of tires at Agostini's! It was my first time doing that sort of distance on a bike.It took 21 days and 14 of those days it rained.
I did a Tour de France on the Ghezzi: 3.500 kms in 5 days.
no tools. no worries either.
