Tony C Posted March 5, 2009 Posted March 5, 2009 The trip Odometer knob came off my V11 speedo. This is a very common problem as I have read here. The bike is a 2004 Billabio. I need some instructions on how to remove and then replace the speedometer since I am going to try to fabricate a permenate solution to the knob falling off, along the lines of what someone posted here not too long ago. I had a link to Guzzi shop manuals but the link does not work any more. Hopefully one of you can give me some advice on removing the thing or point me to some instructions. I am going to fabricate a new knob and then lubricate the insides to try to make the thing last a bit longer. I don't want to break anything in the process. Thanks, Tony C
Admin Jaap Posted March 6, 2009 Posted March 6, 2009 You can download the V11 Manuals here: http://www.angelfire.com/weird2/v11/ Removing the speedo is a very easy job, just think logical and you'll have it removed in less than 10 minutes.
Tony C Posted March 6, 2009 Author Posted March 6, 2009 Thanks for the info. Looks like this weekends project. T
Greg Field Posted March 7, 2009 Posted March 7, 2009 Tony: While you're in there, strongly consider lubing the speedo. They last longer if you do. Here's a primer on how: http://www.v11lemans.com/forums/index.php?...5&hl=speedo Since writing that, I've change the procedure somewhat. I use a Dremel cutoff wheel chucked in my drill press to cut open the case. Takes about 30 seconds.
Tony C Posted March 11, 2009 Author Posted March 11, 2009 Thank you for the advice. The speedo came out quit easy. The only problem I had was the rubber light holder things. Real tough to get out and very delicate. Still trying to find a screw that will hold the knob on the trip odometer. T
