Benny Posted April 6, 2009 Posted April 6, 2009 I own a 2005 Ballabio. I want to change the turn signals and go for a smaller option. However they are mounted with 6mm bolts (as alot of you would know!) Does anyone know where I can source turn signals that come with 6mm studs and (same wiring set up) and that are smaller than the standard ones?? I'm not real keen on "tapping" out the existing mounting holes if I can help it... Or the other alternative is to replace the cracked front turn signal lense after a recent trip to the World Supers at Phillip Island. Can anyone help me with sourcing one for my Ballabio?? They are clear lenses...
grossohc Posted April 7, 2009 Posted April 7, 2009 Benny said: Or the other alternative is to replace the cracked front turn signal lense after a recent trip to the World Supers at Phillip Island. Can anyone help me with sourcing one for my Ballabio?? They are clear lenses... The clear lenses/indicators are the same as the ones used on the aprilia tuonos. Triumphs also use similar, easy enough to get on fleabay Gary
Benny Posted April 19, 2009 Author Posted April 19, 2009 grossohc said: The clear lenses/indicators are the same as the ones used on the aprilia tuonos. Triumphs also use similar, easy enough to get on fleabayGary Thanks Gary. Got a pair off ebay for about 30 bucks Australian. Problem solved!! Ben
