waspp Posted April 11, 2009 Posted April 11, 2009 I just noticed my side stand on the 03 LeMans was loose and upon further inspection the casting broke where the lower bolt threads in. I just wondered if this has happened to anyone else and if so did you manage to have it successfully welded. I guess the other option is to locate another casting. Suggestions and ideas wellcome. Hal
savagehenry Posted April 12, 2009 Posted April 12, 2009 I remember this coming up before, and the best solution was to buy a new inner/upper sump. I recall they were in the $130.00 range.
Guest ratchethack Posted April 12, 2009 Posted April 12, 2009 Hal, there was a pretty good write up on this a year ago here: http://www.v11lemans.com/forums/index.php?...st&p=144047.
waspp Posted April 12, 2009 Author Posted April 12, 2009 Thanks for the heads up guys. It's hard to believe you could get that sump spacer for $135, thats not to bad.
mznyc Posted April 13, 2009 Posted April 13, 2009 Hal ,Glad you didn't find out about that the hard way while leaned over in a turn. Stoopid Luigi
waspp Posted April 24, 2009 Author Posted April 24, 2009 Just an update: I was fortunate enough John here on the board had a used sump spacer and the bike is back together ready to go! An interesting find in the process was the sidestand bracket mounts differntly from an 02 to 03-04. My sump had one mounting hole and a fairly large bolt going through the bracket and into the sump. The 02 sump had two threaded holes smaller in size than mine. This leads me to ask if the newer bikes had more breakage issues than the previous models? Does the 02 sidestand use both threaded holes in the sump to mount the bracket? Inquiring minds have to know!
Tom M Posted April 26, 2009 Posted April 26, 2009 Does the 02 sidestand use both threaded holes in the sump to mount the bracket? Inquiring minds have to know! My '02 has a large bolt and a small bolt (M6). PS thanks for posting your Ti can repair over in the how-to section Hal. Unfortunately I had to use it yesterday, but I'm happy with the results.
