Tanzi Posted April 17, 2009 Posted April 17, 2009 My 03 LeM Rossa Corsa has developed the bounding tech issue. Can someone walk me though installing the ground to stop the bounce? I tryed to add a ground to the mounting screws and it did not help. TIA
The Monkey Posted April 20, 2009 Posted April 20, 2009 My 03 LeM Rossa Corsa has developed the bounding tech issue. Can someone walk me though installing the ground to stop the bounce? I tryed to add a ground to the mounting screws and it did not help. TIA Search tachometer failure, and you will have the thread on the solution, Im doing the same with mine, good luck
