Steve W Posted April 17, 2009 Share Posted April 17, 2009 The tops of the fork tubes on my (new to me) '02 LeMans are about 1" above the top of the upper triple clamp. Is this normal, or did the PO make an adjustment? The bike has a set of Verlicchi bars/risers on and I'd like to get the bars up a little higher - but with it as it is currently, things will start running into the fairing at the extremes of steering if I raise them at all. If I drop the fork tubes down, it should give me the room I need (if I'm thinking about this correctly). Thanks, Steve Link to comment Share on other sites More sharing options...
gstallons Posted April 17, 2009 Share Posted April 17, 2009 The standard clip-on is mounted on the top of the triple clamp. that is why you see the 25mm of the fork tub extending through the triple clamp. Link to comment Share on other sites More sharing options...
Admin Jaap Posted April 17, 2009 Share Posted April 17, 2009 As I recall, the OEM clipons were mounted on top of the triple tee, so the fork tubes stick out about an inch. Dropping the fork tubes will not help you. You will be able to adjust the Verlicchis, but your actual bar height won't be higher. Another thing to think about: dropping the forks will affect the handling (and not in a positive way) The fairing just isn't made for higher bars. That's why I took it off to fit Ballabio bars. Link to comment Share on other sites More sharing options...
gargoyle Posted April 17, 2009 Share Posted April 17, 2009 The fairing just isn't made for higher bars. That's why I took it off to fit Ballabio bars. Nope, you can get higher bars on a LeMans. I have a pair of Convertabars on mine and they are great. I'm using all stock lines and it got me to just the right spot. http://www.convertibars.com/ProductsBike.c...=+Next+Step%21+ Link to comment Share on other sites More sharing options...
Steve W Posted April 18, 2009 Author Share Posted April 18, 2009 The standard clip-on is mounted on the top of the triple clamp. that is why you see the 25mm of the fork tub extending through the triple clamp. Well, ok - that's why I was wondering. I guess I might be able to pick up a little by rotating the Verlicci clamps toward the back of the bike and pivoting the bars forward to maintain the angle - I should be able to raise them up a little more while bringing them back toward me. Maybe that'll be enough. Thanks, Steve Link to comment Share on other sites More sharing options...
