SBJ Posted April 21, 2009 Posted April 21, 2009 Mine moves backwards and forwards a little bit as if the mounting bolt has worked loose resulting in this play. Should it do this? Hs it shaken loose a little and the bolts need tightening up, or is it designed to do this. Sorry if indeed it is a stupid question but it is new to me and I have only just taken delivery of it. What a beautiful bike!
Guest ratchethack Posted April 22, 2009 Posted April 22, 2009 SJB, it's mounted on spherical bushing links. It's the way it's designed, and no prob.
Tom M Posted April 22, 2009 Posted April 22, 2009 Congrat's on your beautiful new bike! The mount that screws into the lower triple clamp has a lock nut on it. If that comes loose the mount might move side-to-side a little bit. Make sure that lock nut is tight.
GuzziMoto Posted April 23, 2009 Posted April 23, 2009 The damper should have play but not in the direction of travel. It should be loose side to side at the frame mount, but it should not have any play in the direction of motion.
