Karl Von Posted April 21, 2009 Posted April 21, 2009 has anyone installed a HD TPS swith in their V11 ? I read the article where they will make the bike run a little rich at low end and lean out on the upper RPM range.
fotoguzzi Posted April 22, 2009 Posted April 22, 2009 Yes, I have one in now. 34 bucks from chicagoharley.com. i read the same article. had a stumble/cough @4200rpm, it got a little better. I need a Mistral crossover, used and cheap, anyone? seat of pants? can't tell any difference. I don't run max speeds (around here it's hard to get into 6th) so I hope the lean condition is a non issue... I just got the Roper plate installed and have all next week off, spring has arrived in Minnesota and if it's not raining for days, I'm gone !
Karl Von Posted April 22, 2009 Author Posted April 22, 2009 Yes, I have one in now. 34 bucks from chicagoharley.com. i read the same article. had a stumble/cough @4200rpm, it got a little better. I need a Mistral crossover, used and cheap, anyone?seat of pants? can't tell any difference. I don't run max speeds (around here it's hard to get into 6th) so I hope the lean condition is a non issue... I just got the Roper plate installed and have all next week off, spring has arrived in Minnesota and if it's not raining for days, I'm gone ! I was thinking about using one in my Centauro and was wondering about the running rich issue from the report. My bike runs rich as it is, so I dont need any more fuel. For 34 bucks it might be worth a try
stormsedge Posted April 23, 2009 Posted April 23, 2009 This interests me...did you recal/reset your TPS after installing the new switch?
fotoguzzi Posted April 24, 2009 Posted April 24, 2009 This interests me...did you recal/reset your TPS after installing the new switch?I think switch is the wrong term but never mind.. Yes I did re-set the base line TPS and re synced TB's then brought the TPS voltage up to near 525Mv at idle (last summer). I don't have the software to set it by degree but I believe I am pretty right on, man I hope she rolls out ready to ride maybe as soon as tomorrow if the weather holds out. I have my other ride out but not tuned so I'll be doing TB sync on the EVert first. and I've been riding the toy since New Years Day!
stormsedge Posted April 27, 2009 Posted April 27, 2009 Is there a part number I can ask for? Thanks. k
