Of course, according to English constables Merriam & Webster, Dampen is OK in this case:
dampening
One entry found.
Main Entry:damp·en
Pronunciation:\ˈdam-pən\
Function:verb
Inflected Form(s):damp·ened; damp·en·ing \ˈdamp-niŋ, ˈdam-pə-\
Date:1547
transitive verb
1 : to check or diminish the activity or vigor of : deaden
2 : to make damp
3 : damp 1c
intransitive verb
1 : to become damp
2 : to become deadened or depressed
— damp·en·er \-nər\ noun
Just a note from the freedom of word choice coalition.
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
This, the correct form of the word, (as used on this thread and others), from Merriam-Webster online:
damper
http://www.merriam-webster.com/dictionary/damper
Main Entry: damp·er
Pronunciation: \ˈdam-pər\
Function: noun
Date: 1707
1: a dulling or deadening influence <put a damper on the celebration>
2: a device that damps: as a: a valve or plate (as in the flue of a furnace) for regulating the draft b: a small felted block to stop the vibration of a piano string cchiefly British : shock absorber
3Australian : a simple usually unleavened bread of a kind made originally in the Australian bush
Hence, the previously posted visual aid:
THIS^ is a STEERING DAMPER.
dampener
http://www.merriam-webster.com/dictionary/dampener
Main Entry: damp·en
Pronunciation: \ˈdam-pən\
Function: verb
Inflected Form(s): damp·ened; damp·en·ing \ˈdamp-niŋ, ˈdam-pə-\
Date: 1547
transitive verb
1 : to check or diminish the activity or vigor of : deaden <the heat dampened our spirits>
2 : to make damp <the shower barely dampened the ground>
3 : damp 1c
intransitive verb
1 : to become damp
THIS^ is a STEERING DAMPENER.
Indubitably brutal, ain't they? ;)
Hence, the previously posted visual aids:
Agreed, as a noun like you are using it.
Although as Ben used it, "dampening fluid" the previous definition fits.
HA, so I was right while being wrong and it all came back around to go forward again, but wouldn't it make a better medium than oil? :huh:
