alabamav11 Posted May 21, 2009 Share Posted May 21, 2009 I have a V11 Sport with electrical problems. Frequently when I start the bike the headlight, brake light, tach, horn, and low fuel light won't work. Possibly it doesn't charge either in this condition but haven't been able to verify that yet. Usually at some point in the ride all these items begin working and continue to work until I shut the bike down. Any ideas? Link to comment Share on other sites More sharing options...
Guest ratchethack Posted May 21, 2009 Share Posted May 21, 2009 The high probability is, it's your LIGHTS relay (#2 front-to-back), but best check the socket also & make sure one of the female spade-type recepticles hasn't been shoved out through the back of the socket. I highly recommend Omron replacement relays from John Mickowski, Forum Member and engineer, by long direct personal experience. You can order at this link, but also check his relay comparo evaluation linked at his site: http://www.motratech.com/Motratech/MGRC20.html Link to comment Share on other sites More sharing options...
alabamav11 Posted December 17, 2009 Author Share Posted December 17, 2009 Got the OMRONS, solved the problem. Thanks! Link to comment Share on other sites More sharing options...
Slavomir Musilek (R.I.P.) Posted December 17, 2009 Share Posted December 17, 2009 mine did the same, so I did the homework and checked all conectors and etc. result was the isolation under the fuse box was too loose and water came in <_> Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted March 27, 2010 Share Posted March 27, 2010 Slightly off topic - when I replaced my relays I added an LED to the base of each one, It tells me if the relay is energized. Link to comment Share on other sites More sharing options...
docc Posted April 26, 2010 Share Posted April 26, 2010 Not 'off topic' at all! Relay quality and connectivity remain the #1 biggest improvement an owner can make to these bikes' reliability. Some bikes have "map pockets" in their tank bags, V11s have "electrical diagram/troubleshooting" pockets . . . Link to comment Share on other sites More sharing options...
