Guzzirider Posted May 26, 2009 Posted May 26, 2009 I noticed when I arrived in Ulster that I had some oil on the right hand side of my rear wheel- nothing to write home about, but after a few hours at 80mph on the way home, the leak had got a little worse and there was some on the edge of the tyre. There was no flood of oil dripping down from the box, but just a small stain indicating a small leak. All the bolts are tight, and I don't think it is the breather so I am guessing I may need to replace the seal(s), a job which I have never had to do before. Looking at the parts manual there are two seals, part numbers 90403850 and 90706958. Am I likely to need to replace both seals? Do I need any special tools for the job? Any advice much appreciated. Cheers Guy
pasotibbs Posted May 26, 2009 Posted May 26, 2009 I noticed when I arrived in Ulster that I had some oil on the right hand side of my rear wheel- nothing to write home about, but after a few hours at 80mph on the way home, the leak had got a little worse and there was some on the edge of the tyre. There was no flood of oil dripping down from the box, but just a small stain indicating a small leak. All the bolts are tight, and I don't think it is the breather so I am guessing I may need to replace the seal(s), a job which I have never had to do before. Looking at the parts manual there are two seals, part numbers 90403850 and 90706958. Am I likely to need to replace both seals? Do I need any special tools for the job? Any advice much appreciated. Cheers Guy Its not a terrible job (unless the leak is from the pinion seal) as you should not need to remove the pinion gear ( a real pain). Thread here and here (the tread I posted pics in) Seals for bevel box are...(prices are 3 years old) BRTS70X85X8 OIL SEAL £1.64 +VAT BRTS32X52X7 OIL SEAL £1.03 +VAT BRTS37X55X8 OIL SEAL £1.64 +VAT BS163 O RING £0.50 +VAT from reading the thread it looks like I found one seal size to be wrong (38x50x7 instead of a 37x55x6 ) but as thats not on the list I'm not sure if there is another seal ? I have a bearing puller if you need it (I can't remember) just PM me.
richard100t Posted May 26, 2009 Posted May 26, 2009 The large outer seal is very easy to do. Just take the wheel off & pry the old one out & press a new one in. The smaller inner seal will require a bearing puller to get at it. I just had this done to my drive & after watching how its done I would say..go get a puller & have a go at it. Try just replacing the easy one first though to see if that does it
mike wilson Posted May 26, 2009 Posted May 26, 2009 You should be able to hire one of these, in the correct size. http://www.cromwell.co.uk/KEN5034720K The separator part is also not so expensive to buy. The rest can be fabricated. http://www.cromwell.co.uk/KEN5034520K
