belfastguzzi Posted June 5, 2009 Author Posted June 5, 2009 It seems that Guzzi made the spring with a bigger coil size to allow for the discrepancy in boss sizes. So if you have the bigger diameter coil you shouldn't need to file the boss down. When fitting it, you can manually check that the coil doesn't bind when it's twisted.
macguzzi Posted June 6, 2009 Posted June 6, 2009 They also do a boss kit with spring not too expensive
DeBenGuzzi Posted June 7, 2009 Posted June 7, 2009 I don't see what he has to do with it almost 19000mi on an double ought and no problems, bikes on third set of relays tho. <_>
