Guest J.R. Posted August 7, 2002 Posted August 7, 2002 I bought a set of gel grips,but hven't a clue as to get the bar end weights off to attach grips.When I insert an allen wrench it just seems to turn,nothing screws in or out.How is this done? <_
Guest Scura Owner Posted August 9, 2002 Posted August 9, 2002 J.R.-Assuming you have a LM or Scura, you have to hold the bar end while unscrewing the allen head bolt. Once you get the bar end off you will understand how the whole anti-vibration system is set up, if interested.
al_roethlisberger Posted August 12, 2002 Posted August 12, 2002 Ha... mine was even more of a pain that that. Even if you held the end, my whole assembly inside still turned and wouldn't come out! I had to turn, pull, turn, pull... then when enough of the "nut" under the plastic end showed, I could get a wrench in there to grab it. Royal PITA But with my Throttlemeisters one now, no problemo al
Woodburn Posted January 30, 2003 Posted January 30, 2003 How do you remove the bar ends on a V11 sport? The process described here doesn't seem to apply. Thanks!
dlaing Posted January 30, 2003 Posted January 30, 2003 I just turned the allen wrench and my bar ends unscrewed. Woodburn, what happens when you attempt this?
Woodburn Posted January 30, 2003 Posted January 30, 2003 Okay, I got it to come off. I just needed to really give it some leverage. Thanks!
