Lars Le Mans Posted June 8, 2009 Author Share Posted June 8, 2009 Ok I adjusted the TPM as ordered It was way of . 246mV fully closed with everything backed off. Luigi most have had hang overs that day. It is now at 156mV fully closed and 468mV at 1000 rpm. It´s a totally diffrent engine, It runs so smooth Link to comment Share on other sites More sharing options...
Guest ratchethack Posted June 8, 2009 Share Posted June 8, 2009 That's great, Lars. You're probably close to "just right" on the TPS. But I'd strongly recommend you get the idle up to 1200 RPM, or you're risking too low oil pressure to the plain bearings at idle. Remember -- the oil pressure idiot light only comes on at 2-5 PSI (0.15-0.35 Kg/cm^2). If you crank up the idle, this should put you close to the following range: Todd Eagan at GuzziTech has always recommended a PROPERLY INDEXED (150 mV disconnected, idle screw backed out, throttle plate fully closed) TPS setting of 500-525 mV @ 1150-1200 RPM idle, TB linkage connected. Link to comment Share on other sites More sharing options...
GuzziMoto Posted June 8, 2009 Share Posted June 8, 2009 Now get to work building that custom exhaust. Pictures when it's done. Link to comment Share on other sites More sharing options...
