how do you remove the clutch lever (stock one) mine moves up and down in the mount on the handle bar is there a bushing in the mount pin ?? and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans
Huh?
If you are attempting to remove the lever only, remove the nut underneath the pivot bolt. Push the pivot bolt up and out of the perch (while you watch for a ball and spring fall to the floor when you do the next step) and remove the lever. Reassemble everything and lightly grease everything you do not want to rust.
...and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans
I needed to give mine a gentle tap from underneath with a rubber mallet.
