hi guys . the speedometer counters packed up recently on my `04 V11 Le Mans so i decided to install a complete new console - a KOSO RX2N .
everything`s working fine with it except that the tacho isnt picking up the rpm . i have tried to install the wiring as per the KOSO unit`s instructions ,but in my opinion they are fairly vague .
anyone out there that has already fitted one of these units or can show me the way - it would be much appreciated . any info on calibrating the unit would also help .
cheers
Canny
  • 10 months later...
`04 V11 Le Mans so i decided to install a complete new console - a KOSO RX2N . everything`s working fine with it except that the tacho isnt picking up the rpm . i have tried to install the wiring as per the KOSO unit`s instructions ,but in my opinion they are fairly vague .
Did you ever get this to work, if not please send me a PM
Roy
cheers
Canny
How vague are the instructions?
  • 4 weeks later...
As in 0 ?
I would assume you would connect to the trigger side of the coil?
  • 4 years later...
I had the need to remove/dig into my 2002 V11 LeMans gauge cluster.  The ground wires on either gauge are a joke.  Not the wires, but the standoffs that are used to "fasten" them.  Recommend getting in there and improving the ground on both the tach and the speedo (at least for your back lighting!)
  • 7 months later...
