raceboy Posted June 25, 2009 Share Posted June 25, 2009 I've been eyeing many of the V11s' with High Mounted pipes, I think they add to the visual appeal of the overall package. The V11 owners who bought the Guzzi Ti kit got a pair of high mount brackets (apparently Daytona 1000 / 1100 / Sport parts) which also have the passenger foot peg bracket built in. I went to the Canadian importer and he checked the parts listings to get me a price ($90/ea....YIKES!) yes Guzzi I know, but also that there was no stock and could not tell me if and / or when they would even be available. So my questions is this.... What other options do I have?????? Maybe something from another bike (any bike Jap, European, etc.) that fits or at least close. I could make a set of brackets but I want the rear pegs. So any ideas, suggestions would be greatly appreciated. Raceboy Link to comment Share on other sites More sharing options...
The Monkey Posted June 25, 2009 Share Posted June 25, 2009 The TLR had high mount duals as did the RC51. Might be priced right in a scrap yard. Good luck! Link to comment Share on other sites More sharing options...
Slavomir Musilek (R.I.P.) Posted June 26, 2009 Share Posted June 26, 2009 I used Sport1100 brackets, which I guessed has the same mounting holes as V11 has. I was wrong just make second hole into the holder attatched to the frame so you can always switch from high mount to low mount. And I have also taken out the passanger footrests. Link to comment Share on other sites More sharing options...
raceboy Posted June 26, 2009 Author Share Posted June 26, 2009 I used Sport1100 brackets, which I guessed has the same mounting holes as V11 has. I was wrong just make second hole into the holder attatched to the frame so you can always switch from high mount to low mount. And I have also taken out the passanger footrests. Slavomir, Do those brackets lay flat? Link to comment Share on other sites More sharing options...
Slavomir Musilek (R.I.P.) Posted June 26, 2009 Share Posted June 26, 2009 Slavomir, Do those brackets lay flat? what do you mean? i dont understand will get some more pics Link to comment Share on other sites More sharing options...
raceboy Posted June 26, 2009 Author Share Posted June 26, 2009 what do you mean? i dont understand will get some more pics The stock brackets had a bend so the exhaust would clear the swing arm & rear drive. The Sport 1100 look like they are flat, with no bend. If you lay them on the table they just lay flat on the table. Raceboy Link to comment Share on other sites More sharing options...
Slavomir Musilek (R.I.P.) Posted June 26, 2009 Share Posted June 26, 2009 The stock brackets had a bend so the exhaust would clear the swing arm & rear drive. The Sport 1100 look like they are flat, with no bend.If you lay them on the table they just lay flat on the table. Raceboy they are not flat, but more "flatter" than those on V11 I dont use the rear hugger and the Mistrals are mounted from outer side of the brackets, no problem so far (even on unwanted over-horizont) jump Link to comment Share on other sites More sharing options...
raceboy Posted June 27, 2009 Author Share Posted June 27, 2009 I spent part of the day yesterday hunting around a couple of motorcycle scrap yards to see if can find any suitable hangers from other bikes, the closest I came was from older R6. I think I will just make my own on the mill. I will post the pics when I'm done. Keep the shiny side up! John Link to comment Share on other sites More sharing options...
