Guest ratchethack Posted August 23, 2009 Posted August 23, 2009 Hmmmmmmm. . . (Part IV) No body, no murder weapon -- nor even a credible clue of a possible murder weapon. . . And yet, there are those who still apparently continue to get slimed by the Legend of the Great Horned Extremely Twitchy Demon. . . Who you gonna call? (turn up the volume) "I ain't afraid o' no ghost." - Ray Parker, Jr.
Greg Field Posted August 24, 2009 Posted August 24, 2009 A deep and compelling response, as usual. At least it was readable this time and didn't make my eyes bleed. Congratulations on the improvements. I no longer believe the legions who say you are incapable of learning . . .
Guest ratchethack Posted August 24, 2009 Posted August 24, 2009 A deep and compelling response, as usual. At least it was readable this time and didn't make my eyes bleed. Congratulations on the improvements. I no longer believe the legions who say you are incapable of learning . . . EGADS! He SLIMED me. I feel so. . . FUNKY. . . (turn up the volume, Part II) http://movies.yahoo.com/movie/1800070006/video
todd haven Posted August 25, 2009 Posted August 25, 2009 I've got this 4 month old Black Lab. He develops a serious twitch after about 20 minutes asleep. Mostly at low speeds. Should I add to or reduce his rake? "]Nero Sorry He's an 09 model, bone stock.
Guest ratchethack Posted August 25, 2009 Posted August 25, 2009 If he's Extremely Twitchy, and there's no explanation for it, he must be possessed. He does look pretty dangerous. How many people has he killed?
luhbo Posted August 25, 2009 Posted August 25, 2009 ...How many people has he killed? It's a Guzzi Engineer, too? The last ones outed on this forum had some similiarities to monkies (or had that been members of the board?) Ah, there is so much knowledge spread over or sunk into this board, it's hard to keep it present all the time. Hubert
luhbo Posted August 27, 2009 Posted August 27, 2009 ....Greg is probably trying to sell this as "wobbling Red Frames", what I think might be a little overstressed. Wobbling Racer .... Greg, you haven't answered yet. Does this video show what you call "wobble". Do you mean this when you said Guzzis went into wobbles and killed or at least severly injured innocent people? What do your sources say? Hubert
Greg Field Posted August 27, 2009 Posted August 27, 2009 Greg, you haven't answered yet. Does this video show what you call "wobble". Do you mean this when you said Guzzis went into wobbles and killed or at least severly injured innocent people?What do your sources say? Hubert Yes. That is what I would call a serious wobble.
Slavomir Musilek (R.I.P.) Posted August 27, 2009 Posted August 27, 2009 Yes. That is what I would call a serious wobble. you will never believe it until you see it
raz Posted November 29, 2009 Posted November 29, 2009 So where is a 1100 Sporti (pre V11) placed in a similar comparison? Wheel base? Rake? Length of stuff? Just for the record, I've found all the nominal numbers now. Whatever good that is... anyway, in case someone needs them: Wheelbase: 1,475 mm Rake: 26° Fork offset: 45 mm Trail: 96 mm Fork length: 760 mm Trail is calculated from wheel radius, rake and offset using this formula. All other numbers are actually specified in the WHB, but not always easy to find. According to some old post here this means the Sporti has different geometry than both breeds of V11's, which was what I wanted to know. Edit: I wrote 80 mm trail at first, I thought it seemed short and yup, it was wrong (I fed degrees to a function that use radians). The geometry isn't that much different to a V11.
