Ralph Werner Posted October 24, 2003 Posted October 24, 2003 Has anyone changed oil in their Ohlins? I don't have a shop manual yet and wondered if special tools and techniques are involved (like the 1100 Sport).
Baldini Posted October 25, 2003 Posted October 25, 2003 See There's specs, procedures & parts diagrams. It's pretty straight forward. Ohlins do a socket (4703-01) to undo the top nuts w/spigots. It's expensive but good. I removed fork tops from damper rods. I used slotted washer to locate on the preload tubes, which you need to compress to get at the nut at top of the damper rods. You could probably drain/refill w/o removing them but it would be a pain. There's a needle & spring at the bottom of the damper rods that'll drop out if you remove them...it's easier to drain all the oil if you do. When refilling take time to expell any air by pumping the dampers slowly, otherwise you'll get a false idea of the oil level. Ohlins give air gap of 85mm w/springs. I'm going to try 90/95mm cos maybe it's a little hard as is... Can't remember any problems. Do get the info off the Ohlins site it's pretty thorough. KB, Wales I just saw Jaap has put Ohlins stuff here, see under "fileshares" .
Ralph Werner Posted October 26, 2003 Author Posted October 26, 2003 Thanks for that info - what a big help.
