tom3 Posted September 4, 2009 Posted September 4, 2009 I'm thinking about swapping the stock mirrors for a pair of bar end mirrors. I see the CRG and Napolean mentioned, and I began looking. I found these on MGCycle: Ken Sean and Napolean Which would you guys recommend? thanks!
Greg Field Posted September 4, 2009 Posted September 4, 2009 CRGs along with heavier end weights. You'll be able to tell if that car behind you is a cop at 100 yards or more. If you never actually look back, the others will do fine.
WellWellWell Posted September 4, 2009 Posted September 4, 2009 I really like the Napoleon bar ends. They have a pretty large coverage area. And they weigh enough to knock down bar vibes better than bar-end weights. My .02.
Dan M Posted September 4, 2009 Posted September 4, 2009 I have the CRG lane splitters on my Tuono. The quality is great but the image in the convex lens is too small for my aging eyes.
GuzziMoto Posted September 4, 2009 Posted September 4, 2009 I like the Napoleans. They are pretty much a full size mirror so you can see what's behind you. They are not as trick as some of the others but they do work for me.
doug m Posted September 7, 2009 Posted September 7, 2009 rizomas are pricey,but really nice quality and looks IMO. check out PJ's parts.
Steve G. Posted September 7, 2009 Posted September 7, 2009 I use Napolean Beren's. BTW, they are available in chrome too. While the Rizomas and CRG's are probably just a step up quality wise, Napoleans are certainly not crap. Stadium's are entry level cost wise, as well as price. Napolean's have convex mirror. I also like the Napoleans because they are heavier, they actually reduced the vibration on the hands, almost like bar end weights. Steve
tom3 Posted September 10, 2009 Author Posted September 10, 2009 Thanks for all your responses. I decided to try a pair of Napoleans.. just ordered them. Now I read that the factory bar end weights are a bear to remove. Is the proper way to remove them to use an allen wrench to loosen the hex bolt at the bar end? I tried it without applying a lot of force, and the controls (where the turn signal and high beam controls are, on the left side) seem to want to turn as well. Do I need to hold them in place while trying to turn loose the hex bolt? Or perhaps I need to hold the factory bar end while turning the hex bolt? Please pardon my newbieness.. thanks.
Tom M Posted September 10, 2009 Posted September 10, 2009 Thanks for all your responses. I decided to try a pair of Napoleans.. just ordered them. Now I read that the factory bar end weights are a bear to remove. Is the proper way to remove them to use an allen wrench to loosen the hex bolt at the bar end? I tried it without applying a lot of force, and the controls (where the turn signal and high beam controls are, on the left side) seem to want to turn as well. Do I need to hold them in place while trying to turn loose the hex bolt? Or perhaps I need to hold the factory bar end while turning the hex bolt? Please pardon my newbieness.. thanks. Welcome tom3! If the controls are turning your handlebar is rotating in the clamp. Tighten the clamp. The trick to getting the stock end weights off is to unscrew the socket screw on the end of the weight while holding the weight to prevent it from rotating too. A strap wrench might be the best tool for this. Vice grips or pliers will work if you can prevent them from scratching and gouging the weight. I wrapped my end weights in duct tape and used big pliers to hold them and luckily did no harm to the weights. Then I bought a strap wrench for next time. Once the end screw is out the weight will pull off the end of the bar. Watch out for the little dowel pin behind the weight, it's easy to lose. Next unscrew the large hex fitting from the end of the bar and the rest of the assembly will pull out of the bar. Done!
mdude Posted September 11, 2009 Posted September 11, 2009 on the earlier version the hex screw IS the bar end weight. Its a right pig to get out. I have tried for three years to get my left side off without succeeding. it bonds with the handlebar. dont dare to use as much force as is needed, and the handlebar itself twists when I try. I would have the napoeleons if I got it off, for that chromed retro look.
