i m searching for some special turn signal that could fit the front of my "bitza".
Searching something like a little bar of diod or something like this ?
Any idea ??
.... I dunno, but I still need to get down to the dealer in Livermore and check out the new '04 Mille to see if those cool integrated signal mirrors will mount up to our LeMans fairing without surgery :P:
  • 1 month later...
  gthyni said:
I ordered a couple of those (in red) to test if they work as rear/brake lights.
from Streetworks
Goran do you have receive & try as turn signals - is this working ?
  zebulon said:
from Streetworks
I got them but haven't had time to mount them.
I was going to use them as rar/brake lights and
it should be simpler than expected.
I thought I had to wire up some resistance circuit
to get two different powers for normal and braking
but it is wire up for that already.
I was thinking of running without turning signals altogether :rasta:
Guest Ragin' Pit Bull
I've ordered some flush LED ones from Lockhart-Phillips. As soon as I get them and put 'em on, I'll post pix.
