battery light
Guest gooddog
The battery light has been flickering on and off for about as of recent, usually while idelling at a traffic light. A twist of the wrist has been able to turn it off, until tonight where it stayed on for several minutes while zipping around town. I recently upgraded two of the relays, but i would imagine that its an alternator issue or just a short. Any suggestions?
Hard to say off-hand, but I'd check all your connectors and especially grounds. Your rectifier could be going south I suppose, and you can test that... although I don't know how :huh2:
But I'd check all the other connectors first. Grounds on these bikes are notoriouslhy finicky :rolleyes:
al
The most common seems to be the connections to the battery itself. Make sure they are snugged up well. :luigi:
And check the path to ground. Did Al mention to check the grounding path? Or the path to ground?
It's probably not the relays. The rectum-fryer is solid state, so when that goes south, it goes all the way south. With your symptoms, it's probably the ground. Did Carl mention to check the ground? :cheese:
Cheers,
Jason
