Greybeard Posted November 27, 2009 Posted November 27, 2009 Especially you lot who've mounted K&N's! Er...well...I'm mounting K&N's so no air box, no temp sensor mount. However, scanning the available real estate I noticed the top shock mount with an approximately 1" hole in the bracket and I'm thinking I'd machine up a small cup with some vent holes in it, mount the sensor in the cup and set the cup in that hole in the bracket. I wouldn't make a vent on the back of the cup so the sensor wouldn't be hit by schmeg kicked up from the rear tire. Nice, cozy, tidy. So? Ya reckon?
luhbo Posted November 27, 2009 Posted November 27, 2009 Put it behind the lamp. Somewhere there in front. When I bought my bike it was mounted there. They've been using a small alu bracket for that. IIRC the wire had to be made longer for that. And it was mounted freely. Hubert
Greybeard Posted November 27, 2009 Author Posted November 27, 2009 Put it behind the lamp. Somewhere there in front. When I bought my bike it was mounted there. They've been using a small alu bracket for that. IIRC the wire had to be made longer for that. And it was mounted freely. Hubert And nothing to protect the little pepito then?
raz Posted November 27, 2009 Posted November 27, 2009 Just keep it away from hot parts or silly amounts of water and you're fine. If your original idea is possible without altering the wires I'd go for that.
luhbo Posted November 27, 2009 Posted November 27, 2009 And nothing to protect the little pepito then? No, nothing, wich was not a good solution. I then put it back to where it belonged to. They don't look very strong, these thingies. I think I've read about putting it into a drilled film box once (if you still have one around). Hubert
emry Posted November 29, 2009 Posted November 29, 2009 I used the top of a spray can (the plastic cap). Not very elegant, but it was easy and has worked well enough.
Admin Jaap Posted November 29, 2009 Posted November 29, 2009 No, nothing, wich was not a good solution. I then put it back to where it belonged to. They don't look very strong, these thingies. I think I've read about putting it into a drilled film box once (if you still have one around). Hubert Yep, that's what I did.
