df2 Posted February 10, 2010 Posted February 10, 2010 Can anyone tell me the parts (nut and cap) that screw into the upper triple. Mine was replaced with a cap like threaded cover that allows my magni fairing frame to screw into the top. I need to replace this. I can't find them on the parts fiche. Thanks David
GuzziMoto Posted February 11, 2010 Posted February 11, 2010 What year/version? 30513401 is the cap/nut for a 01-02. Look through the parts lists in the links section here... http://66.196.80.202/babelfish/translate_u...ts_list/gb/1100
abarth Posted June 20, 2010 Posted June 20, 2010 Anyone know how to remove shiny cap on upper triple clamp?
gstallons Posted June 20, 2010 Posted June 20, 2010 Take a small reg. tip screwdriver and pry it off.
Tom M Posted June 21, 2010 Posted June 21, 2010 The stainless steel cap on my '02 steerer tube is screwed on and it definitely won't pry off. I wrapped some plier jaws with tape so I wouldn't scratch things up and unscrewed it when I was removed my top triple clamp. Once I had it off I realized that the raised center section of the cap is a plastic cover with an allen key type socket underneath. Maybe that little center cap can be pryed off or pushed through?
