scre103 Posted March 6, 2010 Share Posted March 6, 2010 Planning on ordering a penske rear shock model 8983, looks similar to the oem white power setup, how long is the hose? I guess i could run a strig along the hose but thought someone might come up with the exact length. thnx Link to comment Share on other sites More sharing options...
CoreyL Posted March 8, 2010 Share Posted March 8, 2010 Planning on ordering a penske rear shock model 8983, looks similar to the oem white power setup, how long is the hose? I guess i could run a strig along the hose but thought someone might come up with the exact length. thnx I just replaced my stock Sachs unit with a Penske unit and they seemed to already know the length of the hose, diameter and width of mounting points, diameter of the remote reservoir, etc. The only difference was the angle at which the hose entered the remote reservoir and I'm not sure how much control they have over that. Hope that helps... Link to comment Share on other sites More sharing options...
GuzziMoto Posted March 8, 2010 Share Posted March 8, 2010 Talk to Michael Himmelsbach at Penske. He had one made up for my wife that worked perfect. Link to comment Share on other sites More sharing options...
dlaing Posted March 21, 2010 Share Posted March 21, 2010 The Penske reservoir does not use the stock holder. It comes with rubber blocks to mount it to the starter. Orienting the hose is a little tricky but doable. They cut it to the perfect length without me specifying. I did have trouble getting the right size bushing spacers from them, but they were great at FedExing the correct ones, but mine was custom ordered to be as close to Ohlins dimensions as possible, so they used different parts which may have triggered the wrong size bushings getting delivered. There support is excellent, so if there is a problem with the length or anything, they will be there for you. I felt treated like a pro racer in race season!!! Link to comment Share on other sites More sharing options...
