wildbill Posted August 13, 2002 Posted August 13, 2002 JohnInNH, was that your champagne with the mistrals and x-over I saw in a certain CT shop over the weekend? Sweet looking setup, do tell how it sounds... did you remap? how's the midrange on that puppy now? any improvement on the ever-present pinging?? I'm jealous! Me thinks I spy an xmas present suggestion for my wife!!! <_ src="%7B___base_url___%7D/uploads/emoticons/default_tongue.png" alt=":P"> WB
Guest JohnInNH Posted August 17, 2002 Posted August 17, 2002 WB, Yep that's mine.... I have not seen it yet, but have heard from 2 people it looks good, and sounds nice too. I may be able to pick it up later today (08/17/02) I have been away for 2 weeks, and have been dying to ride it. I have a PC III which is sitting on my desk and I will put it on when I get the bike back. I plan on taking it to Manchester NH to have a custom map made. I can not comment on how any of the changes to the bike work yet. John at Marsh likes the way the pipes sound, and told Al he may put a set on his bike. I just got off the phone with John, and hs is road testing it now... I will call back in a couple of hours and see if I can get it later. Then I will install the PC III and load a close map until I have it custom mapped. More later.
Guest JohnInNH Posted August 18, 2002 Posted August 18, 2002 I picked up the Le Mans, and have taken it out for a test run with the x-pipe and slip-ons. It sounds nice, and seems to pull smoother in the lower and mid range. Not having the mixture correct now makes me hesitate to ride it a lot. I installed the PC-III with the M706-001 map which came installed on the PC-III. The zero map would be better as it is to lean with . The 2500 RPM area is WAY to lean. Since you can not load maps w/o the PC installed on the bike It is impossible for me to load the M06-003 map as I do not have a laptop or a PC in the garage. The Bike will not make it up my front steps into the living room either. So I will disconnect the PC-III till I get a way to load maps. The stock map is better than one which came with the PC-III because of my pipes and x-pipe. I will order a Palm adapter, and see if I can borrow a laptop in the mean time. I have been putting off buying one, I may bite the bullet and get one. It's a shame the PC can not talk to the PC-III off the bike. It's a lot easier to take the PC-III to the PC than the PC to the PC-III on the bike. I hope I can get a map made shortly. Seems a lot of Dynojet locations are "Harley Only" :finger: Sure makes it inconvenient for a lot of Power Commander owners. Update: I Ordered the Palm adapter and also a devise which lets you update the PC-III while it is not on the Bike, a Remote Power Adapter for $10 and a you supply the needed 9 volt battery. Slick... Just what I needed! Now the wait.
Guest Guest_WildBill Posted August 19, 2002 Posted August 19, 2002 John, I was intrigued by the bar end weights you have there. Where did you get those? Do they help with that annoying high-frequency vibration? An hour or so in the saddle and my hands are ready for bed... I think I'm gonna put on some Gel Grips but i'm wondering if the stock bar end weights could be improved as well...
Guest JohnInNH Posted August 19, 2002 Posted August 19, 2002 Bill, The bar end weights are in-fact the Throttlemeister throttle lock/friction units. They make two sizes .. Mine are the heavy ones. Look for the "thread" here as there is a lot of info here already. Vibration? What vibration? I must be missing something. I felt that the Le Mans had only a slight vibration compared to my HD and British twin BZZZZZZZZZZZZ The Throttlemeister units did smooth what little was coming through, but I still feel the motor. It IS a motorcycle
