I read the tech note about doing the valves. I have been putting this task off because I don't have new gaskets.
Is it OK to put the old ones back?
BTW, where do I get a decent manual for V11 Sport?
Thanks
Roy
Thanks
Roy
you can reuse those gaskets forever. just use care when you remove the cover so they don't tear.
You may have to add a little silicone (very little)to seal the old gasket, if you do tear it British Italian or Chilliwack Yamaha will have them. I just got a set of re-usable silicone gaskets from Real Gaskets Tennessee. They look like a good product so in they go next adjustment. They are online the part number for them is RG-14023760-2
MG-3760 S/2
Likewise a CD covering parts and procedures is constantly available through Ebay for $10 USD
Happy Thrashing, hope this helps :bike:
MG-3760 S/2
I dont Have a gasket in mine at all and they dont leak. I just used some high temp silicone and it works great. Now of course thats just a temporary thing as when I do the valves again I'll have to clean the old sealer off. But by then I'll have gotten some new gaskets.
That's great guys.
I will have at it then.
Will check out the manuals on the site you provided.
Roy
I downloaded the manuals V11 & Supplement.
They all seem to come in 3 languages, rather than print all pages and throw away the ones I didn't need I took the file to work and opened the pdf with an edit program we have.
I was able to get rid of nearly half the pages and print it out double sided.
If anyone would like a copy of the abbreviated pdf send me an e-mail roy_matson at yahoo dot ca
Regards
Roy
  • 3 weeks later...
Well what i did when i had this issue was buy some gasket paper, I placed the rocker cover on the scanner bed and scanned the head and just printed the image onto the gasket paper.
if you wish i can send you a copy of the original image i used as a template for the gasket?
total cost - €1 and works a treat.
Dave
Roy, Dave,
Greg Bender has been a wonderful resource for ALL Guzzisti for quite a while now- he hosts many technical documents and collected advice,etc.
I would ask that you send your files to him for posting on his website. That way, everything is at a central location and you won't be bothered with tens of emails. :cheese:
Cheers,
Jason
What an excellent idea! I think you deserve a bodge point for that!
OTOH, I don't know where one gets gasket paper in 8.5x11" size sheets stateside... :huh2:
