My '03 Lemans has a red and white plastic elbow. Is the white an inlet? If so... for gas or air? I'm confused as to why no other bike seems to have both a red and white. Even Todd at MPH (Houston) hasn't heard of a second white elbow.
My white is broken and will need to be fixed. I've seen one fix, but am thinking an actual brass elbow type fix. Most importantly, what the heck is the mysterious white elbow do (that I broke)?
-Kevin
Not having seen one, I'll take a SWAG. It's the tank breather line that goes to the charcoal cannisters and then to the throttle bodies. If the fuel vapor recovery system has been removed you probably have a drain line that goes down alongside the back of the transmission.
