neophyte Posted April 30, 2010 Posted April 30, 2010 Well I'll get right to the heart of the matter. My Front Ride Height (F1-F3): 43 MM My Rear Ride Height (R1-R3): 38 MM I weigh about 190 lbs and am 5 foot 9 inches tall - stocky. I don't really have enough riding experience to diagnose if I need more this or that on my settings, but I would say I wondered about the rear. I have a hunch or feel it kind of squats down maybe more in back, and maybe I sense a little understeer or maybe not....that is just my ignorance. Freeing up grabbing brakes: I did not find a suitable tool on hand to rotate the buttons but with patient penetrant application and mallet tapping I feel I freed them up pretty good and hope brake grabbing will be abated. How to measure sag with a book bag and a little sister: I took careful measurements of the front and rear unloaded (I have a stand). I then loaded up a backpack with Guzziology, Pons full size German-English dictionary, some tomes on unreadable things in hardcover, put my riding jacket on, and then I sat on my guzzi in best riding position - although with my left hand on a wheelie bin to steady the bike, while my little sister took measurements with the tape like I instructed her to do. Her numbers were in the right direction and she couldn't be too far off the mark. But lets say +/- 2-3 mm: Anyone have thoughts on how to proceed? What say useall about my measurements? Thank you in advance,
Baldini Posted May 1, 2010 Posted May 1, 2010 To adjust preload, I just tapped adjuster & lock rings around using a large flat screwdriver. I think I just removed seat, & lifted rear of tank a little. Be slow & careful so's not to damage anything. KB
neophyte Posted May 1, 2010 Author Posted May 1, 2010 To adjust preload, I just tapped adjuster & lock rings around using a large flat screwdriver. I think I just removed seat, & lifted rear of tank a little. Be slow & careful so's not to damage anything. KB Thanks Baldini, I may try that if I decide I don't want to mess with removing tank. I don't have a garage to work in and the weather looks spotty so may try this route.
docc Posted May 2, 2010 Posted May 2, 2010 Here I thought the airbox had to come off as well . . None the less, Increasing your preloads will certainly help the sag. Your target numbers are around 25-30 mm (25-30% of travel) and , some say, a bit more sag to the front. An extra 5mm makes the street more friendly. The final solution will be correct springs for your riding weight; likely something a bit stiffer than your stock fitment. I found that increasing fork preload on the soft front springs for my 180# weight limited rebound travel enough to scuff my leathers. . .
tmcafe Posted May 2, 2010 Posted May 2, 2010 The only time when the airbox absolutely has to be removed is if you want to remove the rear shock (I had to replace mine under warranty). Either way, it's a PITA to adjust shock preload. Wonder why in the world they put a C shock spanner in the tool kit (which doesn't fit the Ohlins anyway).
rocker59 Posted May 3, 2010 Posted May 3, 2010 The one time I've messed with the rear shock/spring, I removed it from the bike.
