sullvarni Posted June 10, 2010 Posted June 10, 2010 On 5/17/2010 at 12:42 AM, docc said: Bob, Could you post a picture of your "modified" grease gun fitting? It would be helpful to know where and how much to grind, and the right fitting to start with to make this a "2 minute job." TIA, docc I agree with Ponti all that talk about removing this and that i did what he did get a swivel head grease tip file it down a little be careful i over did my first one and have at it,fiddly yes but a lot less hassle than dismantling the rear end,i can never get pics to this site but will endeavor to do so as i have a good shot of said grease fitting. Stu.
gommista Posted June 10, 2010 Posted June 10, 2010 On 5/11/2010 at 5:04 AM, galaxiid said: On my '03 Cafe Sport I have greased the two rear unijoint grease nipples (on the driveshaft). No worries. This is straight forward. The front unijoint is suppossed to have a grease nipple. This topic is discussed in one thread here. I went to much trouble to remove the three allen bolts that secure the cover over the front unijoint. This to move it back and around to try and locate a grease nipple. And does one exist? No, I could see nothing at all. So is this a myth or did MG drop the nipple off this model? I can see if a nipple did exist then it would be incredibly difficult to access it. But I honestly searched and looked and mulled over this before deciding that no there is no front grease nipple on the unijoint. Am I right? Is there a thread someone can point me to that can resolve this issue once and for all? Thanks in anticipation...
docc Posted June 10, 2010 Posted June 10, 2010 On 6/10/2010 at 6:07 AM, gommista said: On 5/11/2010 at 5:04 AM, galaxiid said: On my '03 Cafe Sport I have greased the two rear unijoint grease nipples (on the driveshaft). No worries. This is straight forward. The front unijoint is suppossed to have a grease nipple. This topic is discussed in one thread here. I went to much trouble to remove the three allen bolts that secure the cover over the front unijoint. This to move it back and around to try and locate a grease nipple. And does one exist? No, I could see nothing at all. So is this a myth or did MG drop the nipple off this model? I can see if a nipple did exist then it would be incredibly difficult to access it. But I honestly searched and looked and mulled over this before deciding that no there is no front grease nipple on the unijoint. Am I right? Is there a thread someone can point me to that can resolve this issue once and for all? Thanks in anticipation... Looks like Galaxiid found his grease fitting in Post #22 on page 2. Hey, Stu, definitely get a pic up of your modified grease gun.
savagehenry Posted June 11, 2010 Posted June 11, 2010 I bought a needle valve. No effin' around, no swivel and no grinding. About 10 bucks as I recall
sullvarni Posted June 13, 2010 Posted June 13, 2010 On 6/10/2010 at 5:19 PM, docc said: ame='gommista' date='10 June 2010 - 01:07 AM' timestamp='1276150037' post='171457'] Looks like Galaxiid found his grease fitting in Post #22 on page 2. Hey, Stu, definitely get a pic up of your modified grease gun. This is it the swivel head filed down a little,and now for the pic I hope this works!It did I'm a freekin Genius,"Not". Stu.
tdisme Posted August 6, 2010 Posted August 6, 2010 On 6/5/2010 at 9:57 PM, twhitaker said: In absence of a lift if you have rope, pulleys, and a couple eye bolts in the ceiling you can remove the seat and haul the bike up. Make sure you secure the front of the bike. Why not use a CanyonDancer and take both ends up?
Greg Field Posted August 6, 2010 Posted August 6, 2010 On 8/6/2010 at 1:24 AM, tdisme said: On 6/5/2010 at 9:57 PM, twhitaker said: In absence of a lift if you have rope, pulleys, and a couple eye bolts in the ceiling you can remove the seat and haul the bike up. Make sure you secure the front of the bike. Why not use a CanyonDancer and take both ends up? In the end, I'm not at all sure that greasing the front u-j matters. After 6000 miles, the front u-j will be stiff. At 32,000 miles and after a lot of greasing, it is still stiff. I have seen many like it. YMMV.
