sullvarni Posted June 10, 2010 Posted June 10, 2010 Bob, Could you post a picture of your "modified" grease gun fitting? It would be helpful to know where and how much to grind, and the right fitting to start with to make this a "2 minute job." TIA, docc I agree with Ponti all that talk about removing this and that i did what he did get a swivel head grease tip file it down a little be careful i over did my first one and have at it,fiddly yes but a lot less hassle than dismantling the rear end,i can never get pics to this site but will endeavor to do so as i have a good shot of said grease fitting. Stu.
gommista Posted June 10, 2010 Posted June 10, 2010 On my '03 Cafe Sport I have greased the two rear unijoint grease nipples (on the driveshaft). No worries. This is straight forward. The front unijoint is suppossed to have a grease nipple. This topic is discussed in one thread here. I went to much trouble to remove the three allen bolts that secure the cover over the front unijoint. This to move it back and around to try and locate a grease nipple. And does one exist? No, I could see nothing at all. So is this a myth or did MG drop the nipple off this model? I can see if a nipple did exist then it would be incredibly difficult to access it. But I honestly searched and looked and mulled over this before deciding that no there is no front grease nipple on the unijoint. Am I right? Is there a thread someone can point me to that can resolve this issue once and for all? Thanks in anticipation...
docc Posted June 10, 2010 Posted June 10, 2010 On my '03 Cafe Sport I have greased the two rear unijoint grease nipples (on the driveshaft). No worries. This is straight forward. The front unijoint is suppossed to have a grease nipple. This topic is discussed in one thread here. I went to much trouble to remove the three allen bolts that secure the cover over the front unijoint. This to move it back and around to try and locate a grease nipple. And does one exist? No, I could see nothing at all. So is this a myth or did MG drop the nipple off this model? I can see if a nipple did exist then it would be incredibly difficult to access it. But I honestly searched and looked and mulled over this before deciding that no there is no front grease nipple on the unijoint. Am I right? Is there a thread someone can point me to that can resolve this issue once and for all? Thanks in anticipation... Looks like Galaxiid found his grease fitting in Post #22 on page 2. Hey, Stu, definitely get a pic up of your modified grease gun.
savagehenry Posted June 11, 2010 Posted June 11, 2010 I bought a needle valve. No effin' around, no swivel and no grinding. About 10 bucks as I recall
sullvarni Posted June 13, 2010 Posted June 13, 2010 ame='gommista' date='10 June 2010 - 01:07 AM' timestamp='1276150037' post='171457'] Looks like Galaxiid found his grease fitting in Post #22 on page 2. Hey, Stu, definitely get a pic up of your modified grease gun. This is it the swivel head filed down a little,and now for the pic I hope this works!It did I'm a freekin Genius,"Not". Stu.
tdisme Posted August 6, 2010 Posted August 6, 2010 In absence of a lift if you have rope, pulleys, and a couple eye bolts in the ceiling you can remove the seat and haul the bike up. Make sure you secure the front of the bike. Why not use a CanyonDancer and take both ends up?
Greg Field Posted August 6, 2010 Posted August 6, 2010 In absence of a lift if you have rope, pulleys, and a couple eye bolts in the ceiling you can remove the seat and haul the bike up. Make sure you secure the front of the bike. Why not use a CanyonDancer and take both ends up? In the end, I'm not at all sure that greasing the front u-j matters. After 6000 miles, the front u-j will be stiff. At 32,000 miles and after a lot of greasing, it is still stiff. I have seen many like it. YMMV.
