Baldini Posted May 14, 2010 Share Posted May 14, 2010 Where are the main earthing points for battery/loom on 02 V11? Thanks KB Link to comment Share on other sites More sharing options...
The Monkey Posted May 14, 2010 Share Posted May 14, 2010 On the casing, just behind the seat release keyway. (02 Lemans) Link to comment Share on other sites More sharing options...
Baldini Posted May 14, 2010 Author Share Posted May 14, 2010 On the casing, just behind the seat release keyway. (02 Lemans) Thanks. Is there another, around the front subframe somewhere? KB Link to comment Share on other sites More sharing options...
Slavomir Musilek (R.I.P.) Posted May 14, 2010 Share Posted May 14, 2010 Thanks. Is there another, around the front subframe somewhere? KB no, the small black wire earths the rectifier. Link to comment Share on other sites More sharing options...
The Monkey Posted May 14, 2010 Share Posted May 14, 2010 There is a small threaded lug on the front frame just behind the oil cooler left side on mine. 5mm, I use it to ground the headlight relays. I am also putting an additional ground from Reg to Bell housing (aft) Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted May 14, 2010 Share Posted May 14, 2010 no, the small black wire earths the rectifier. On my bike this one was under one of the horn mounting bolts, looks like 18 AWG or similar not big enough IMHO. The same current flows here as in the 30Amp fuse circuit. I beefed this up with a cable from regulator fin to one of the timing cover bolts Roy Link to comment Share on other sites More sharing options...
jrt Posted May 15, 2010 Share Posted May 15, 2010 I added a wire from the triple clamp to the engine on a 2001 V11 sport. Otherwise, the headlight ground path is through the steering head bearings. J Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted May 16, 2010 Share Posted May 16, 2010 For the past couple of weeks I have been chasing a elusive fault, battery goes flat, the engine spits and starts every now and then and the tacho occasionally drops to zero. This evening I strapped my multimeter to the tank ad connected to the two red wires from the regulator, the negative terminal I put under one of the radiator screws. I expected to see the battery charging but to my surprise the voltage would jump from 12-15-10-13 all over the map. From this I have deduced that I have a bad ground somewhere, this would explain at least the charging and tacho, hopefully the missing also. If you think your relay bases are a problem see my thread on overhauling the bases, about 2 hours work Hope this helps Roy Link to comment Share on other sites More sharing options...
docc Posted May 17, 2010 Share Posted May 17, 2010 Most of the grounds (earths) are back through the harness to the (nefarious) stack of terminals on the battery. The regulator and the instrument illumination both, apparently, ground to their mounting. the whole system does benefit from enhancing the ground paths, from anchoring the bulb holders in the instruments to adding a ground strap between the engine and frame, or building a junction block to get the terminal stack off the battery. Because the engine is "stressed" and becomes a conduit for earthing, it's probably good medicine to remove/clean, and apply copper anti-seize to the frame mounting bolts. Link to comment Share on other sites More sharing options...
