Hello,
I'm new to Guzzi's and trying to understand the adjustments that need to be made to make it run correctly. The bike stumbles at 2-2300 rpm. It idles fine and does great above 2300 rpm. I was really confused about the TPS adjustments. Which wires do I check? Does this mean I need to get the ECM re-flashed?
Thanks, Brendon
Hello,
Thanks, Brendon
do you still have the stock crossover? theres a couple aftermarket x-overs that can improve that stumble.. do a search.. no you don't need to re-flash anything. start with valve adjustment, then get into the TPS (do a search) and balance the throttle bodies.
also find your way to guzzitech.com and http://wildguzzi.com...x.php?board=1.0
see ya there!
Brendan,
No need to "re-flash." In fact, a good tune up works magic on these machines: TPS adjustment
And, always good medicine to service your relays: Relay Base Repair
Keep us posted how it goes. I once heard it said that these motorcycles enjoy a bit of "owner involvement.":rolleyes:
