And the left side.
These are my prototypes. The screw joining the two pieces will not be there. That was just to jig it so I can get it welded in the right spot.
It's a rider not a queen. I washed it last year. Check out the starter bolts. That's what happens when you wash it.
I know I'd be in for a set!!
Gotcha down for one set on the Wildguzzi board unless you want another set.
I'm painting the prototype and should have them installed in the next couple days. Pictures to follow.
no I just need the one set, just wanted to make sure I was in on it. NOW that I really look at it, I might have a problem, I don't know if these can even mount up to my bike, I see that support bar you got there is NOT present on red framed bikes, I might not have anyway to mount these up
but is present on the newer bikes
I don't think I have a mounting point and might have to be out :(
I have them painted and installed. Right side.
On the way to work I realized two benefits. The feet on the forward pegs takes some of the weight off my hands. My wife can reach forward and use my pegs.
