Kiwi_Roy Posted June 8, 2010 Posted June 8, 2010 (edited) Three more sketches ECU test points , this is for the ECU with the square multi-pin plug, if anyone wants I can do another for the long plug Troubleshooting tips, a few troubleshooting ideas I picked up over the years Charging Circuit, simple wiring. The current readings I got are probably different than yours but it should give you an idea. Cheap multimeters will have quite a bit of voltage drop which will also effect the readings, I suggest you make a shunt or use an automotive type meter. Having just rebuilt my regulator i can draw the schematic in my sleep. for those electronicly inclined i will forward a copy if you send me a PM Hope this is of interest Roy ECU Test Points May 12 2010.pdf Troubleshooting Tips.pdf Charging Circuit.pdf Edited June 8, 2010 by Admin Jaap changed topic title for easier searching
