It doesnt seem like its available on their pages, but is there a PC3 option for a newer bike, like a 2003-2005 with lambdas and "cat"? Can they make use of the existing model PC3 USB?
I would ask Todd @ GuzziTech. He probably sells more PowerCommanders for Guzzis then any one else.
As far as I know the one issue is any changes made to the fuel curve in the closed loop part of the map will be undone by the O2 sensor. I believe Todd can alter your ECU to remove the O2 sensor input. He can also hook you up with a PCV and an AutoTune module that will allow you to set air/fuel target numbers and it will adjust the mix to meet your targets.
