javahouse Posted June 22, 2010 Share Posted June 22, 2010 Hi Thought I'd mention, the front UJ yoke on my 2003 V11 - screw was tight, but the yoke was still sliding on the shaft. I tightened it further, and stopped it, but did wonder if it was perhaps supposed to slide? Thanks Rob Link to comment Share on other sites More sharing options...
raz Posted June 22, 2010 Share Posted June 22, 2010 No, it should not slide. This usually happens unless you cross torque it in several steps. Link to comment Share on other sites More sharing options...
gstallons Posted June 22, 2010 Share Posted June 22, 2010 Hopefully you are talking about the pinch bolts that holds the yoke on the output shaft. This should be tight and the yoke NOT slide on the shaft. Tighten them both equally to about 30 ft.lb. of torque. Link to comment Share on other sites More sharing options...
javahouse Posted June 22, 2010 Author Share Posted June 22, 2010 That's good then, but a lot more than 30lbs Ta Rob Link to comment Share on other sites More sharing options...
gstallons Posted June 22, 2010 Share Posted June 22, 2010 You are talking about the 8mm bolts? Link to comment Share on other sites More sharing options...
