belfastguzzi Posted July 30, 2010 Share Posted July 30, 2010 Hi Jaap For making replies, is multiquoting working? I couldn't get it to work. D Link to comment Share on other sites More sharing options...
Admin Jaap Posted July 30, 2010 Share Posted July 30, 2010 Works fine, just Multiquote-click the posts you want to quote and click Add reply. Link to comment Share on other sites More sharing options...
testmember Posted July 30, 2010 Share Posted July 30, 2010 Hi Jaap For making replies, is multiquoting working? I couldn't get it to work. D Works fine, just Multiquote-click the posts you want to quote and click Add reply. Like this. Link to comment Share on other sites More sharing options...
belfastguzzi Posted July 30, 2010 Author Share Posted July 30, 2010 Like this. Ah, that's not what I was trying to do. So I misunderstood its purpose. I wanted to have an original post plus its reply as shown in the reply post, both showing in my reply to the reply. When I make a reply to a post that has the two messages there, only the last writer's post shows in the reply. Using multiquote, you have to go to the two posters rather than have both copied from the second 'reply' post. Hmmm. Link to comment Share on other sites More sharing options...
belfastguzzi Posted July 30, 2010 Author Share Posted July 30, 2010 Ah, that's not what I was trying to do. So I misunderstood its purpose. I wanted to have an original post plus its reply as shown in the reply post, both showing in my reply to the reply. When I make a reply to a post that has the two messages there, only the last writer's post shows in the reply. Using multiquote, you have to go to the two posters rather than have both copied from the second 'reply' post. Hmmm. This is a reply. It doesn't contain the first post quoted in the post I'm replying too. Link to comment Share on other sites More sharing options...
belfastguzzi Posted July 30, 2010 Author Share Posted July 30, 2010 Hi Jaap For making replies, is multiquoting working? I couldn't get it to work. D Works fine, just Multiquote-click the posts you want to quote and click Add reply. Like this. Whereas if i go to individual posts and click 'multiquote' and then 'add reply' it shows the multiple original posts. Ha hmm Link to comment Share on other sites More sharing options...
Admin Jaap Posted July 31, 2010 Share Posted July 31, 2010 This is a reply. It doesn't contain the first post quoted in the post I'm replying too. Correct, that's a setting, I think. I believe I can change that if you like. Link to comment Share on other sites More sharing options...
Admin Jaap Posted July 31, 2010 Share Posted July 31, 2010 This is a reply. It doesn't contain the first post quoted in the post I'm replying too. Correct, that's a setting, I think. I believe I can change that if you like. This is what you wanted, isn't it? Link to comment Share on other sites More sharing options...
belfastguzzi Posted August 1, 2010 Author Share Posted August 1, 2010 This is a reply. It doesn't contain the first post quoted in the post I'm replying too. Correct, that's a setting, I think. I believe I can change that if you like. This is what you wanted, isn't it? Yes. I've just seen it happen when I posted! Have you changed for the whole Board? If people don't like it I'm quite happy for you to turn it off again. Link to comment Share on other sites More sharing options...
belfastguzzi Posted August 1, 2010 Author Share Posted August 1, 2010 This is a reply. It doesn't contain the first post quoted in the post I'm replying too. Correct, that's a setting, I think. I believe I can change that if you like. This is what you wanted, isn't it? Yes. I've just seen it happen when I posted! Have you changed for the whole Board? If people don't like it I'm quite happy for you to turn it off again. In fact it is better to be off, as it was, if it is a generic setting. Replies will become gigantic. Thanks Link to comment Share on other sites More sharing options...
Admin Jaap Posted August 1, 2010 Share Posted August 1, 2010 You can also add a reply without quoting. Link to comment Share on other sites More sharing options...
