Paul Minnaert Posted November 14, 2003 Share Posted November 14, 2003 In germany have people been called to come back to get some parts replaced. it's To be changed: for the frames KR and KS 2 bolts from the crankshaft, and manicotto parastrappi und manicotto scorrevole and as far as I can find, that are parts in the gearbox. Not the sping! Link to comment Share on other sites More sharing options...
docc Posted November 15, 2003 Share Posted November 15, 2003 I don't have the Italian translation in my shop manual, only the German and, I believe, Dutch. I wonder which parts and bolts these are? And, this is for the Rosso Mandello only? I can't imagine these parts would be unique to that model? Link to comment Share on other sites More sharing options...
Paul Minnaert Posted November 15, 2003 Author Share Posted November 15, 2003 on the cd look at: Doppelschiebemuffe “D”, Einzelschiebemuffe “E” drawing : v11\css\v11_186.htm Kupplungsmuffe “L”, drawing : v11\css\v11_185.htm these are gearbox parts. I did a text search on all the files from the cd and found these. One german with a grey v11 had a letter too. Link to comment Share on other sites More sharing options...
docc Posted November 16, 2003 Share Posted November 16, 2003 These are the double and single sliding sleeves of the secondary shaft, often called 'sliding dogs.' The 'Kupplungsmuffe' is the sleeve on the transmission shaft. For those who recall the Cycle World long term test bike, these are some of the parts replaced on it when its 'shift quality' degraded. This was , apparently, due to improper heat treatment of the early parts. But, but, . . . the Rosso Mandello is a 2001, yes? Wouldn't all '00 and '01 gearboxes be alike? And , perhaps, even 2002? Link to comment Share on other sites More sharing options...
roberto Posted November 17, 2003 Share Posted November 17, 2003 It was the sliding dog part which shattered on my Scura, resulting in the entire gearbox being replaced. The part exibited a brittle fracture consistent with a heat treatment issue. Link to comment Share on other sites More sharing options...
scre103 Posted November 17, 2003 Share Posted November 17, 2003 "can you hear me now" , didn't i say there would be a v-11 recall related to the trans! . Link to comment Share on other sites More sharing options...
V11UK Posted November 17, 2003 Share Posted November 17, 2003 Just so I can add this topic to my ever growing list which is entitled 'What may go wrong with my 1999 V11 - but hasn't yet'....what happens when this gearbox fault occurs? Is it all the gears which are affected or just one or two? Link to comment Share on other sites More sharing options...
al_roethlisberger Posted November 17, 2003 Share Posted November 17, 2003 "can you hear me now" , didn't i say there would be a v-11 recall related to the trans! . ....no one doubted you, we just asked if you had more info as it's hard to follow-up with so little to go on from the initial post But yes, thanks al Link to comment Share on other sites More sharing options...
docc Posted November 18, 2003 Share Posted November 18, 2003 what happens when this gearbox fault occurs? Is it all the gears which are affected or just one or two? Cycle World reported that the shift quality on their long term test bike degraded. I wasn't sure what this meant until, at 16,500 miles, my shift quality degraded. Lots more false neutrals and missed gears. This is likely the more common circumstance than the ' full grenade.' In my experience third gear was most affected. But , this means upshifting from 2 to 3 or , 3 to 4 as well as downshifting from 4 to 3 or 3 to 2. With the sliding sleeves, it is the gear change which is affected. And who was it who said their third did grenade? Link to comment Share on other sites More sharing options...
V11UK Posted November 18, 2003 Share Posted November 18, 2003 what happens when this gearbox fault occurs? Is it all the gears which are affected or just one or two? Cycle World reported that the shift quality on their long term test bike degraded. I wasn't sure what this meant until, at 16,500 miles, my shift quality degraded. Lots more false neutrals and missed gears. This is likely the more common circumstance than the ' full grenade.' In my experience third gear was most affected. But , this means upshifting from 2 to 3 or , 3 to 4 as well as downshifting from 4 to 3 or 3 to 2. With the sliding sleeves, it is the gear change which is affected. And who was it who said their third did grenade? This web site is fast becoming 'required reading'. Thanks for the prompt answers to any questions posted. Link to comment Share on other sites More sharing options...
Paul Minnaert Posted November 18, 2003 Author Share Posted November 18, 2003 I found on the guzzisti it groups: FROM chassis chassis N° ZGUKR0000XM11112 to ZGUKR0000YM112130 FROM chassis chassis N° ZGUKR0000YM112131 to ZGUKR00001M114639 FROM chassis chassis N° ZGUKS00001M111111 to ZGUKS00001M111147 FROM chassis chassis N° ZGUKS00001M211111 to ZGUKS00001M211162 should problem bikes. TLM said that all first series and rosso mandello are in. Link to comment Share on other sites More sharing options...
callison Posted November 18, 2003 Share Posted November 18, 2003 Well, I wonder if the zeroes in the center are real or just place-holders. My 2001 V11 Sport falls handily into the range: ZGUKR00001M114639, but only if the center zeroes can be another code, in my case, it's: ZGUKRAKR21MXXXXXX Link to comment Share on other sites More sharing options...
Paul Minnaert Posted November 18, 2003 Author Share Posted November 18, 2003 Carl, looks like yours isn't in the range. first 2 are KR serie, 3 and 4 are KS series. Then you look from the right, so you have a 1m114639 that is beyond the 3 range. But ask the dealer to be shure. Link to comment Share on other sites More sharing options...
Guest John T Posted November 18, 2003 Share Posted November 18, 2003 O.K. My tranny is in the recall group. I was wondering, can these trannys be shimmed like the 5 speeders to help get rid of some of the slop? Pete? If my tranny is coming apart, why not improve it if possible? Well at least they don't have to get into my engine. the Carrillo rods have been "rev limiter" tested" Good timing for a recall though, winter is good for these type of chores. Link to comment Share on other sites More sharing options...
al_roethlisberger Posted November 18, 2003 Share Posted November 18, 2003 I'll have to head home and check the "chassis number", but does this relate to the engine number? I do have that handy. - Engine Number: KR 015765 Whaddya think, am I "in" or "out" BTW, do we have a Service Bulletin or Recall # to reference? al Link to comment Share on other sites More sharing options...
