pasotibbs Posted September 9, 2010 Posted September 9, 2010 Anyone know the size of the gear selector shaft oil seal ? Mine is leaking and I don't want to pull it apart until I have a replacement to hand if possible.
gstallons Posted September 9, 2010 Posted September 9, 2010 Anyone know the size of the gear selector shaft oil seal ? Mine is leaking and I don't want to pull it apart until I have a replacement to hand if possible. Do you have a MG dealer near you?
pasotibbs Posted September 10, 2010 Author Posted September 10, 2010 Anyone know the size of the gear selector shaft oil seal ? Mine is leaking and I don't want to pull it apart until I have a replacement to hand if possible. Do you have a MG dealer near you? Dealer is 45 miles away, bearing/seal shop (choice of 2) is 2 miles
luhbo Posted September 10, 2010 Posted September 10, 2010 Anyone know the size of the gear selector shaft oil seal ? ... 15 26 7 BA - from V11Sport.de Also try this link: http://www.stein-dinse.com/eliste/index.php?sid=ggg&lg=en or this one: http://www.hmb-guzzi.de/shop Following the one or other link you may end up here: Hubert
pasotibbs Posted September 10, 2010 Author Posted September 10, 2010 Anyone know the size of the gear selector shaft oil seal ? ... 15 26 7 BA - from V11Sport.de Also try this link: http://www.stein-dinse.com/eliste/index.php?sid=ggg&lg=en or this one: http://www.hmb-guzzi.de/shop Following the one or other link you may end up here: Hubert perfect, I may even be able to get one on my way home tonight.
