wheels off
rossi46
Hi, Just removed my rear wheel, my first time!, to do the cush drive, I have read Docc's checklist and have some questions- where do I find the rear drive and g/box vents? also the brake carrier block I just unscrewed the block(rather than remove the bolt) why lube this and what sort of torque should I use when putting wheel back on? thanks :thumbsup:
The rear drive vent is in top of the rear drive - easy to see. the gear box vent is between the output shaft and the clutch slave cylinder - not easy to see.
The rear wheel spindle torques to 120 NM (from the "drive side")
I don't see how you have "unscrewed" the brake block without taking out the bolt? The block should just slide off.
grease or neversieze should be ok.
Um, be careful when you try to dissasemble the cush drive. The bolts (they are hex bolts, right?) are very, very soft. They also have threadlock on them, so heat them up if you can.
Oh, and the vents look like little square-profile mushroom caps. Easy to spot, as Docc points out.
