cycles4fun Posted September 24, 2010 Posted September 24, 2010 Hey guys I need an expert opinion. Other then balancing, Is a crank from a V1100 California and a V1100 Lemans the same. The answer is obvious as the part numbers are different, however if its only a minor balance change this could easily be corrected with rebalancing. I understand the pistons are likely a different weight which will require a different balance. I need a good crank for my 2003 Lemans motor or undersize bearings and a remachining. I can get a good motor for just a bit more then it would cost to rebuild my crank plus I get all the other bonus parts. If the crank is significantly different then its obviously not worth it. I dont mind rebalancing it as I'm going with different pistons anyway. Thanks for your speedy reply.
cycles4fun Posted September 24, 2010 Author Posted September 24, 2010 Hey guys I need an expert opinion. Other then balancing, Is a crank from a V1100 California and a V1100 Lemans the same. The answer is obvious as the part numbers are different, however if its only a minor balance change this could easily be corrected with rebalancing. I understand the pistons are likely a different weight which will require a different balance. I need a good crank for my 2003 Lemans motor or undersize bearings and a remachining. I can get a good motor for just a bit more then it would cost to rebuild my crank plus I get all the other bonus parts. If the crank is significantly different then its obviously not worth it. I dont mind rebalancing it as I'm going with different pistons anyway. Thanks for your speedy reply. Sorry gentelmen, I just realized I have asked this question previously "crankshaft interchangability" but really never got an answer. Perhaps someone has a new take on this topic.
pete roper Posted September 24, 2010 Posted September 24, 2010 Hey guys I need an expert opinion. Other then balancing, Is a crank from a V1100 California and a V1100 Lemans the same. The answer is obvious as the part numbers are different, however if its only a minor balance change this could easily be corrected with rebalancing. I understand the pistons are likely a different weight which will require a different balance. I need a good crank for my 2003 Lemans motor or undersize bearings and a remachining. I can get a good motor for just a bit more then it would cost to rebuild my crank plus I get all the other bonus parts. If the crank is significantly different then its obviously not worth it. I dont mind rebalancing it as I'm going with different pistons anyway. Thanks for your speedy reply. Sorry gentelmen, I just realized I have asked this question previously "crankshaft interchangability" but really never got an answer. Perhaps someone has a new take on this topic. Just off the tio of my head the stroke is the same and they both use a Ducati alternator. Ipso facti they should be interchangeable. Bearing sixes have been the same since God was a boy. Pete
cycles4fun Posted September 25, 2010 Author Posted September 25, 2010 Hey guys I need an expert opinion. Other then balancing, Is a crank from a V1100 California and a V1100 Lemans the same. The answer is obvious as the part numbers are different, however if its only a minor balance change this could easily be corrected with rebalancing. I understand the pistons are likely a different weight which will require a different balance. I need a good crank for my 2003 Lemans motor or undersize bearings and a remachining. I can get a good motor for just a bit more then it would cost to rebuild my crank plus I get all the other bonus parts. If the crank is significantly different then its obviously not worth it. I dont mind rebalancing it as I'm going with different pistons anyway. Thanks for your speedy reply. Sorry gentelmen, I just realized I have asked this question previously "crankshaft interchangability" but really never got an answer. Perhaps someone has a new take on this topic. Just off the tio of my head the stroke is the same and they both use a Ducati alternator. Ipso facti they should be interchangeable. Bearing sixes have been the same since God was a boy. Pete Thanks Pete, Yea I figured the same just did not want to be stuck with a boat anchor of a crank. I have not weighed each to compare. I guess If I want to play it safe I should just get the bearings and get it done. Like most Guzzi guys I'm a bit of a tight wad so always looking for a bargain!
fotoguzzi Posted September 25, 2010 Posted September 25, 2010 why not buy Carl Allisons V11 sport motor, it's ugly outside but nice inside.. He's ready to almost give it away.. located in Ok or Arizona i think.. he's on the wildguzzi site. tell him fotoguzzi sent ya!
